Use the following procedure to display the admin status of the Gateway.
show isis spbm
Switch:1>show isis spbm ============================================================================================ ISIS SPBM Info ============================================================================================ SPBM B-VID PRIMARY NICK LSDB IP IPV6 MULTICAST SPB-PIM-GW INSTANCE VLAN NAME TRAP -------------------------------------------------------------------------------------------- 1 10,20 10 0.00.77 disable enable disable enable Gateway ============================================================================================ ISIS SPBM SMLT Info ============================================================================================ SPBM SMLT-SPLIT-BEB SMLT-VIRTUAL-BMAC SMLT-PEER-SYSTEM-ID INSTANCE -------------------------------------------------------------------------------------------- 1 primary 00:00:00:00:00:00 -------------------------------------------------------------------------------- Total Num of SPBM instances: 1 --------------------------------------------------------------------------------
If the controller and gateway are both enabled on the node
Switch:1>show isis spbm ============================================================================================ ISIS SPBM Info ============================================================================================ SPBM B-VID PRIMARY NICK LSDB IP IPV6 MULTICAST SPB-PIM-GW INSTANCE VLAN NAME TRAP -------------------------------------------------------------------------------------------- 1 10,20 10 0.00.77 disable enable disable enable controller /gateway ============================================================================================ ISIS SPBM SMLT Info ============================================================================================ SPBM SMLT-SPLIT-BEB SMLT-VIRTUAL-BMAC SMLT-PEER-SYSTEM-ID INSTANCE -------------------------------------------------------------------------------------------- 1 primary 00:00:00:00:00:00 -------------------------------------------------------------------------------- Total Num of SPBM instances: 1 --------------------------------------------------------------------------------
